Hello,
I would like to how can i get the interface list(similar to SMT-->Interfaces-->Interface list) from powershell.
Thanks,
Rupesh
Hello,
Thanks,
Rupesh
Hi PI team, correct me if I'm wrong.
Sure, here's how you can get a list of interfaces using PowerShell, similar to what you see in SMT (System Management Tools):
1.Install PowerShell Tools for the PI System: Ensure you have the PowerShell Tools for the PI System installed. These tools are included with PI System Management Tools (SMT).
2.Import the Module: Import the OSIsoft.PowerShell module if it's not already imported.
<Import-Module OSIsoft.PowerShell>
3.Connect to the PI Data Archive: Use the Connect-PIDataArchive cmdlet to connect to your PI Data Archive.
<$piServer = "YourPIServerName">
<Connect-PIDataArchive -PIDataArchiveMachineName $piServer>
4.Retrieve the Interface List: Use the Get-PIInterface cmdlet to retrieve the list of interfaces.
<$interfaces = Get-PIInterface -PIDataArchiveMachineName $piServer $interfaces>
This script will connect to your PI Data Archive and retrieve the list of interfaces, similar to what you would see in SMT under Interfaces.
Hello AndryanMalino,
Thanks for your swift reply on this.
I have checked the command "Get-PIInterface", but could not find this command in OSIsoft.powershell.
Even i checked it on AvevaDoc(https://docs.aveva.com/bundle/pi-powershell/page/html/R_Project_PI_Powershell.htm) as well, but could not find "Get-PIInterface".
Thanks,
Rupesh
Hello RupeshK ,
I also don't see a Get-PIInterface cmdlet with OSIsoft.Powershell and believe AndryanMalino will have some customization including a Get-PIInterface cmdlet.
PI Interfaces registrations, if configured using PI ICU, are persisted to the PI Module Database (MDB) which appears not accessible through OSIsoft.Powershell and I know that using AF SDK is also not an option because AF SDK doesn't provide access to the MDB. You will have to look into using PI SDK or a dependent Developer Technology like PI OLEDB Provider.
