What is the difference between the collector: Adapter, Connector e Interface?
Hi ErikTavares ,
We have a KB about this question. Please refer to the link below.
KB01871-What are the differences between PI Adapters, PI Connectors, and PI Interfaces
Adapters support non-Windows Environment. Connectors are based on slightly more modern architecture than the PI Interface. Interfaces are generally more battle-tested out in the field.
Hi, i tried to access the page but the message bellow was shown.
Hello ErikTavares ,
You have already registered an SSO account which is the prerequisite to post at PI Square. Many knowledgebase articles require a Customer Portal Login.
Please refer to How to Get A Login.
I have a PI dev Club user that allows me to post to PI Square Email:. I also have a user on https://my.osisoft.com/. But I can't browse the site and see what's there
Hello ErikTavares ,
Email addresses are sensitive information. You should never post your email address publicly.
Did you check How to Get A Login?
Did you validate your email address?
Did you purchase a PI Dev Club subscription?
At which point are you facing an issue?
OK Gregor, thanks for the advice, i removed the email.
How to get a Login? I have a login, and i can enter the website, but the message above is showed, you do not have access to this page
Did you validate your email address? Yes
Did you purchase a PI Dev Club subscription? Yes, i have a PI Dev CLub subscrition and i downloaded the PI Server with it.
At which point are you facing an issue? I only need to undertand the difference between interfaces, connector and adaptors, in a simple way,
in brief.
Hello ErikTavares ,
I am trying to help but please understand that I will not copy the content of any knowledge article.
I have checked the link (Missing Content) shared above and ran into an error. The correct link should be What are the differences between PI Adapters, PI Connectors, and PI Interfaces.
I am not an expert on these details and would refer the contact options offered in the document that I have shared with you. What I can tell is that there is a significant difference between owning an SSO account and having a Customer Portal Login. We know that just the SSO account is not good enough to view all existing knowledge articles.
However, as far as I can see the SSO profile you are using to post here has no PI Dev Club subscription linked to it and was not used to download any setup kit. Could be that II am doing something wrong but that's what I am seeing. Did you eventually use a different account with the subscription / download?
I'm trying to access this document but however I search I'm getting "No articles found". I'm assuming this is since the move over to the AVEVA article database.
Do you have a link that works or some hints how to find this and other articles on the AVEVA system?
