Class Not found exception java.lang.ClassNotFoundException: com.osisoft.jdbc.Driver
Hi All,
I was able to teats a java code that connects to some PI servers and gets data on my PC .
I am now trying to deploy my java code to our test server . I installed the following softwares  on the test server
a) OSI Prerequiste Kit
b) PI OLEDB-Enetrprise software
c) PI sql Data access server
d) PI JDBC
I setup connections to the different PI servers
I was able to connect through PIOLEDBTester.exe and run my queries and get data back from PI servers.
I verified that a class path is setup on the server . It has the value of C:\Program Files\PIPC\JDBC\PIJDBCDriver.jar;.
I added the PIJDBCDriver.jar file to my project library and deployed the  code. I verified that the Driver file is included on my project jar file .
When i run my code on the server i get the following error
My code
          String driver = "com.osisoft.jdbc.Driver";
          Properties plist = new Properties();
          plist.put("user",prop.getProperty("PIUN"));
          plist.put("password",prop.getProperty("PIPW"));
          System.out.println("DATA COLLECTION: Connect to PI" );
          Class.forName(driver).newInstance();
          conn = DriverManager.getConnection(connectionString,plist);
I am getting the error at the line " Class.forName(driver).newInstance();     "
Java Error
01/12/2015 11:40:37 -  at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
01/12/2015 11:40:37 -  at java.security.AccessController.doPrivileged(Native Method)
01/12/2015 11:40:37 -  at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
01/12/2015 11:40:37 -  at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
01/12/2015 11:40:37 -  at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
01/12/2015 11:40:37 -  at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
01/12/2015 11:40:37 -  at java.lang.Class.forName0(Native Method)
01/12/2015 11:40:37 -  at java.lang.Class.forName(Class.java:169)
Any help will be highly appreciated.
Thanks
Kiran
