Powershell ISE - Create file with 10 minute averages
I have a powershell ise file that i inherited from a former employees work - this creates a 10 minute averages file of multiple input tags.
The only issue is that the csv file is outputted in:
Start Time, End Time, TagName, Value
where it appends Tag1, Tag2, Tag3 etc
When it needs to be:
Start Time, Tag1 Value, Tag2 Value, Tag3 Value
The current code is below - any ideas on how to change the output bit to get the required format?
[CmdletBinding()]
param(
  [Parameter(Mandatory=$true,Position=0)]
  [string]$PIDataArchiveMachineName,
  [Parameter(Mandatory=$true,Position=1)]
  [string[]]$PITagMasks
# Connect to PI Data Archive
$con = Connect-PIDataArchive -PIDataArchiveMachineName $PIDataArchiveMachineName
# Get start time as beginning of previous hour & end time as beginning of current hour
[string]$currentHourAsString = Get-Date -Format "dd-MMM-yyyy_HH"
[string]$end_time = Get-Date -Format "yyyy-MMM-dd HH"
$end_time = $end_time+":00:00"
[DateTime]$end_time = $end_time
[DateTime]$start_time = $end_time.AddHours(-1)
# Define Output File
$csvRootPath = "E:\CSV Folder\"
$csvPath = $csvRootPath + $currentHourAsString + "_TenMinSummaries.txt"
# Get collection of all PI Points to have summary calculations
Foreach ($PITagMask in $PITagMasks)
  $pipoints = $pipoints + ( Get-PIPoint -Name $PITagMask -AllAttributes -Connection $con )
$stringPIPointNames = $pipoints.Point.Name
$uniqueStringPIPointNames = $stringPIPointNames | Select-Object -Unique
# set up start time, end time, and number of intervals
$times = @($start_time,$end_time)
$intervals = ($end_time-$start_time).TotalMinutes / 10
# iterate through each PI Point returned and calculate summaries
foreach ($uniqueStringPIPointName in $uniqueStringPIPointNames)
  $expression = "`'$uniqueStringPIPointName`'"
  $tenMinuteAverages = Get-PIExpressionSummary -Times $times -Intervals $intervals -SummaryType Average -Basis EventWeighted -Expression $expression -Connection $con
  $output = $tenMinuteAverages | Select-Object -Property @{Name='StartTime';Expression={$_.StartTime.ToLocalTime()}},@{Name='EndTime';Expression={$_.EndTime.ToLocalTime()}},@{Name='PI Point';Expression={$uniqueStringPIPointName}},@{Name='Average';Expression={$_.Values.Values.Value}} | Export-Csv -Path $csvPath -Append -NoTypeInformation
