How do clear or reset an Ad Hoc trend when working with asset table? I can click on a row and reset the ad hoc to all the tags on that row, but I can't reset the ad hoc using an attribute column. Looks like I can only add.
I find that to be a problem too, and the only way I've found is to just repeatedly click the trashcan on the lowest visible item in the list. That still leaves you with one item, but at least it's manageable at that point. It isn't ideal.
IMHO, there ought to be a Clear Ad Hoc option on the Ad Hoc dropdown menu.
