Does PI Vision 2023 SP1 Patch 1 include a SQL database update?
I didn't see any documentation, but it looks like SP1 is when they finally moved the allowed DA / AF servers from web.config to SQL, so yes, I do believe there are SQL updates.
That's your case, I cannot view that. But if you put the details here, I can try to help.
Case Number: 01160822
Hello Kliff,
Brax here, and I greatly appreciate you reaching out to AVEVA PI Technical Support. Based on the inquiry within your email, I wanted to inform you that PI Vision 2023 SP1 Patch 1 does NOT include a SQL Database Update. Below I've included Case Notes with the Resolution Portion providing an article outlining the PI Vision SQL Database Version History. With this article being updated as this email is being typed, by tomorrow (2/14), you will be able to further confirm on your own that there's no inclusion of a SQL Database Update within PI Vision 2023 SP1 Patch 1. Should the attached article not effectively launch, it's also included within the Linked Content Tab of this Case Feed. Please let me know if you need any further clarification. Thanks so much for your patience!
Resolution
But I found his answer confusing. This was my response:
Thanks for your help, but your response confuses me. The article you reference shows the dbo Version of PI Vision 2023 SP1 Patch 1 is different than the dbo version of 2023 SP1. And yet you insist the article supports your statement that there is no dbo update for the Patch 1 release.
Can you help me understand this apparent discrepancy?
From the article:
Version dbo.Version
PI Vision 2023 SP1 Patch 1 - 3.9.0.0 3.9.1.0
PI Vision 2023 SP1 - 3.9.0.0 3.9.0.0
I noticed my mistake now. There are database changes for PI Vision 2023 SP1, but there are not changes for PI Vision 2023 SP1 Patch 1. I reviewed the included SQL and did not spot any changes, and that is reflected by the version being 3.9.0.0 in the dbo.Version table.
Confirmed. Brax tried to explain in his first message that the article was being updated and that today, the published article would show no dbo changes. Now I understand.
