I was working on a backfilling script using powershell. I want analysis named 'Calculate Value' from a specific element template named 'myElementTemplate'. How can I get those analysis using 'AFAnalysisSearch' using af sdk ?
  • using OSIsoft.AF;
    using OSIsoft.AF.Analysis;
    using OSIsoft.AF.Search;
    using OSIsoft.AF.Asset;
    using System;
    using System.Collections.Generic;
    class Program
      static void Main(string[] args)
        // Connect to the PI System and Database
        PISystems piSystems = new PISystems();
        PISystem myPISystem = piSystems["PISystemName"];
        AFDatabase myDatabase = myPISystem.Databases["AFDatabaseName"];
        // Specify the element template name
        string elementTemplateName = "myElementTemplate";
        // Fetch the element template
        AFElementTemplate elementTemplate = myDatabase.ElementTemplates[elementTemplateName];
        if (elementTemplate == null)
          Console.WriteLine("Element template not found.");
          return;
        // Specify the criteria to search for analyses
        string query = $@"Template:'{elementTemplateName}' Name:'Calculate Value'";
        // Create the AFAnalysisSearch object
        AFAnalysisSearch analysisSearch = new AFAnalysisSearch(myDatabase, "AnalysisSearch", query);
        // Execute the search and iterate through results
        IEnumerable<AFAnalysis> analyses = analysisSearch.FindObjects();
        foreach (AFAnalysis analysis in analyses)
          Console.WriteLine($"Analysis Name: {analysis.Name}, Element: {analysis.Element.Name}");
  • ​ I tried it, but template name takes the "analysis template name" i.e. "Calculate Value" in my case. It does not relate it with specific element template name. So, it will take all the analysis template named "Calculate value" in any element template.
