Hello everyone,
What is your name, position, and company?
I'm Gabriel Marilican, Automation and Control Engineer.
What industry are you in?
I currently work for a mining company.
Does your company already use the PI System? If so, do you know how to use it?
Yes, it uses the PI System for reporting, data management and workflows, fault analysis, and deployment to other sources.
In what ways do you use PI to perform your work or how would you like to use PI to solve problems in your line of work?
I have worked on the installation, configuration, and commissioning of virtualized systems, extensively using the PI software library, integrating solutions with OPC UA/DA, system administration, and I have given talks on integration and use of platforms such as PI Vision, PI AF, PI Datalink, and the important tools for OPC integration for various clients and data source providers.
