1.    How likely is it that you will know (or be given) every PI Point name you need to work with? It is very difficult, almost impossible.
2.    Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank? First I would create a display using an AF Template for MixingTank1. Second I would switch context to MixingTank2, using this option in PI Vision, and be careful about having a good model to allow switch context.
3.    Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
I will have to put the Tags manually.
