1.    How likely is it that you will know (or be given) every PI Point name you need to work with? - Almost never.
2.    Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank? - Templatize the display with AF and build the MixingTank2 using the template. You can then switch assets in Vision
3.    Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework? - Without using AF you will have to pull in individual PI Tags.
