1. How likely is it that you will know (or be given) every PI Point name you need to work with? this would be nearly impossible. And very similar to our current system.
2. Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank? If linked through the AF should be easy to assign to secondary equipment type.
3. Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework? linking the data and these new products to the forecast in your Pi vision reports.
