- How likely is it that you will know (or be given) every PI Point name you need to work with?
  1. How likely is it that you will know (or be given) every PI Point name you need to work with?
  • I might be given them, but it will be difficult to know every single one.
  1. Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
  • If there is even the possibility of needing another display, I will ensure to use the asset framework backbone to easily add the second tank.
  1. Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
  • I would need to know the PI point name and then I can put the point on the display.
