- How likely is it that you will know (or be given) every PI Point name you need to work with? >> even if it's given, it will be complicated to memorise them all and it's not a good way to move forward.
  1. How likely is it that you will know (or be given) every PI Point name you need to work with? >> even if it's given, it will be complicated to memorise them all and it's not a good way to move forward.
  2. Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank? >> a. navigate to the asset tab on top of the screen, click on the dropdown and change it to mixing tank2.
  3. Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework? >> add PI tags.
