1.  How likely is it that you will know (or be given) every PI Point name you need to work with?
  • Unlikely, unless the PI names are encoded. For example, I can search all the PI Tags in my unit because of a unique qualifier.
2.  Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
  • I would copy the display and reference the alternate tags. It would be a manual process and I would potential need to build an additional set performance equations which is double work.
3.  Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
  • I would need to setup some logic to qualify the timestamp data with a certain combination of products to distinguish the batch history.
