1: How likely is it that you will know (or be given) every PI Point name you need to work with?
Ans: It's not necessary that you know every Point and it will be given to you because here it's not required as from AF, you can select required PI points or asset attribute by wild searching *Asset*.
2: Your boss sees your great work and says that MixingTank2 should have the same display, how do you build out another display for the second mixing tank?
Ans: Another display is not required as you can navigate to Asset tab and use current Mixing tank display for display for any other MixingTank2.
3: Next week, you know that the products in your mixing tanks will change. How would you get this new information onto your display without the use of Asset Framework?
Ans: If you have PI points configured for Product Name or recipes of product, display value will change in display as your recipe changes. Or if product in mixing tank is changed, it will come from any other tank, then that tank will be active, and its respective parameters will change in display.
