I have a Tricon CX PLC Controller that is connected to:
1- Engineering Workstation that shall Have AVEVA Intouch window viewer and window maker on it, and a standalone HMI application
also, the workstation has a DDE server installed on it, Tags in the Intouch application will be connected to this server to read the tags and write tags to the controller
2-P6 Harmony PC BOX with 19’’ inch Touch Screen on the System Panel Door that shall have the same standalone application runtime working on it
3-Operators' workstation in another building connected to the Touch screen, Engineering workstation and the controller with a fiber optic cable and all the Components are connected to a switch, this workstation also runs the same Standalone runtime application on it
Note: The application has 2500 Tag, and all the Workstations and PC BOX have windows 10 Operating system
- Do I have to choose the application server product when installing the InTouch window viewer and window maker?
- Where can I get the Exact Part numbers of the AVEVA Intouch Licenses required for this setup and the description for the capabilities of each license?
- Do I need to purchase an SQL Server License or not or SQL Express will be enough, I'm planning to use the Alarm DB logger for historical alarms and events?
- How many tags and for how Long the Intouch HMI Data Logger Can Logs the data to view in historical Trends without AVEVA Historian installed?
