Disabling 'Analyzing tags' each time I make a change
I am working with the Graphics Builder and each time I save a change on an object, the 'Analyzing Tags' dialog is displayed. I can click 'Abort' but I'm thinking that that may be other way to disable this.
Any idea?
Thanks,
Arian
  • It sounds like you have enabled auto refresh on your IO Device configuration. It will try to resync the tags each time you make any change, which can be extremely tedious. I'd recommending setting it to 'FALSE' and manually importing your tags when you make a change on your PLC tag database. See this section in the help for details:
    https://gcsresource.aveva.com/Citect/WebHelp/citect2018/Content/Linking_Tags_to_an_External_Data_Source.html
    Or the IODevice form for more detail of each field (External Properties):
    https://gcsresource.aveva.com/Citect/WebHelp/citect2018/Content/Add_an_IO_Device.html
