We are using Plant Scada 2023 R2 and OFS 3.63 SP3. When we are communicate to Quantum over modnet alarm server works but when we are trying to communite over OFS in this time alarm server doesnt work. any alarm doesnt come to scada.
Hi NAmık Kemal Yıldız ,
I assume that you are using OFSOPC driver in your Plant SCADA project in communication with OFSOPC server. Are your server components running in the service mode? Please refer to the following KB article on Aveva Technical Support website. Hope it will help you to resolve the issue.
https://softwaresupportsp.aveva.com/en-US/knowledge/details/000035307?lang=en_US
Regards,
Jacky
Thanks Jacky. We tried it but in this case OFS stoped working. Do you have any other suggestion ?
Apart from your alarms not working, do you have normal communication for your real-time values (no #COM or #BAD visible on screen)?
If real-time data is not working as well, please inform us what configuration steps you took to convert from MODNET to OFSOPC, like:
- I/O device: Driver should be OFSOPC; Address should be the same name as the name of the PLC defined in the OFS Configuration Tool.
- Variables: For legacy modbus/TCP communication (like MODNET) without performance benefits, you can keep the MODBUS addresses unaltered.
For performance optimized communication, you have to change the addresses to name-based standard OPC tag syntax (conform the variable names used in your PLC application). You have to enable data-dictionary in your PLC-application and in the OFS configuration tool as well. Please consult the appropriate manuals for details.
If only the alarms are not working, you might consider deleting your alarm database.
To do this, please remove the complete alarm database folder which can be found as a subdirectory in the PlantSCADA data folder.
In either case, please consult the PlantSCADA syslog***.dat files for more information on your issue. These can be found in the PlantSCADA log folder.
Please take a look at section of "Chapter 5. OFS as NT Service" of OFS user manual that should be installed along with OFSOP server. Have you tried OFS client to verify OFSOPC server works properly before running Plant SCADA project? You should also review the OFS configuration with OFS Configuration Tool.
