Hello everybody! Today I'm going to talk about my favorite programming language: Python. More specifically, how to integrate Python and our beloved AF SDK in order to extract data from PI. PI and Python? Let's call it PIthon.
Some of you may be wondering why would one do that. (If you are not, jump to the next paragraph). Well, Python has a very active community and is a well established programming language. It's multi-platform and has an uncountable number of libraries and tools. It's also heavily used for big data analytics when used together with libraries like SciPy and NumPy.
First, let me explain why I'm not using IronPython. If you don't know what it is, let me get its description: "IronPython is an implementation of the Python programming language targeting the .NET Framework and Mono.". See the problem? It's an implementation (C# if you are wondering) and not pure Python, so it frequently has problems integrating with third-party libraries. Also, it targets Mono (i.e Linux) and currently AF SDK does not support it. Last but not least, the latest stable release was almost two years ago, so things may be very outdated.
So let's start. For this tutorial you will need:
- A Windows box
- Python 2.7
- AF SDK (Included in the AF Client installer)
- Pythonnet
Proceed with the installation of everything and once it's done, go ahead and create a module called PIthon. Now comes the most important part: libraries import.
import sys
sys.path.append('C:\\Program Files (x86)\\PIPC\\AF\\PublicAssemblies\\4.0\\')
import clr
clr.AddReference('OSIsoft.AFSDK')
And that's all. No kidding. It's so simple I don't dare to explain it. The important thing is that from here you can use a syntax that resembles a lot C# development. Start by importing classes:
from OSIsoft.AF.PI import *
from OSIsoft.AF.Search import *
from OSIsoft.AF.Asset import *
from OSIsoft.AF.Data import *
from OSIsoft.AF.Time import *
Now let's create two important functions.
def connect_to_Server(serverName):
    piServers = PIServers()
    global piServer
    piServer = piServers[serverName]
    piServer.Connect(False)
def get_tag_snapshot(tagname):
    tag = PIPoint.FindPIPoint(piServer, tagname)
    lastData = tag.Snapshot()
    return lastData.Value, lastData.Timestamp
Did you notice how close to C# development this is? Most of the time is pretty much the same, but let me give you a very important tip : PythonNet does not handle well optional parameters from .NET assemblies, so you always need to be explicit. That's why I had to pass False on piServer.Connect. The explicit parameter allows me to dodge the optional parameter problem.
Well, from here you have your module, so let's use it! Go ahead and create a new script and use PIthon:
from PIthon import PIthon
PIConnector.connect_to_Server("Server")
value, timestamp = PIConnector.get_tag_snapshot('sinusoid')
print('Timestamp: {0} Value: {1}'.format(timestamp, value))
And if you run this...
Timestamp: 8/1/2016 5:03:59 PM Value: 73.48035
Voilà! See how simple it was? From here you have the base to create your own AF SDK module for Python! And if you have any questions, feel free to ask them!
Have fun coding with PIthon!
  • Hi, I'm trying to get the pointcount for each pointsource (from pointsource table) and for each scan class (scan class are 15 in number). To get this viewed in a web browser, Django is used.
    in this process, I'm trying to extract the pointcount for each pointsource and for each scan class, but getting error. can someone help me with this?
    Line in bold is giving me error.
    def connectiontoserver(request):
    try:
    if request.method=="POST":
    servername = request.POST.get('serverName')
    (servername)
    global piServer
    piServer = piservers[servername]
    pointsources = [pointsource.Name for pointsource in piServer.PointSources]
    for pntsrcs in pointsources:
    for i in range(15):
    pastring = "PointSource=" + pntsrcs + "and" + "Location4=" + str(i)
    cnt = PIPointList()
    cnt = len(list(PIPoint.FindPIPoints(piServer,pastring,None,None)))
    return render (request,'Pointload.html',{'pisrv':servername,'pointsources':pointsources})
    else:
    message = messages.warning(request, 'Problem in receiving data from serverlist')
    return render (request,'Pointload.html',{'message':message})
    except:
    message = messages.warning(request, 'Connection failed for selected server')
    Error Message:
  • I have the same question.... i need convert time to another time format...
    I tried this:
    tm = event.Timestamp.LocalTime
    tim = tm.strftime("%d %b %Y ")
    but shown me this error:
    AttributeError: 'DateTime' object has no attribute 'strftime'
    SOLVED!!!
    I used ToString() Method to convert data time!! nice!
    Maksim Ivakin try this! import datetime
    tim = tm.ToString()
    date_time_obj = datetime.datetime.strptime(tim, '%d/%m/%Y %H:%M:%S')
    print('Date:', date_time_obj.date())
    print('Time:', date_time_obj.time())
    print('Date-time:', date_time_obj)
    Works fine for me!
  • Hello, Rafael
    Could you please to help me with some easy questions?
    1. I can't to find how to get the previous and next values for attributes (where ConfigurationString is PIpoint)
    2. when we use var=AFTime('t-1d') we get '15.09.2019 00:00:00', how can we convert var to '15.09.2019 00:00'
    or '15.09.2019'
    Thank you for your time
  • Hi, Why when i want to use a condiction for two different types of data does it give me an error?
    The data type is AFEnumerationValue when the data is a binary value like 0 or 1.
    I want to convert AFEnumerationValue type to int type to manage it. I have this function:
    def value_tag(tag):
     try:
     pt = PIPoint.FindPIPoint(piServer, tag)
     current_value = pt.CurrentValue()
     if type(current_value.Value) == float:
     return round(current_value.Value, 1)
     elif type(current_value.Value) == AFEnumerationValue:
     return current_value.Value
     except Exception as ex:
     print(ex)
    def manage_value_tag():
     valuetag = value_tag(SC.SI512154.MSC)
     if valuetag > 0:
     print('is OK')
     else:
     print('is OK')
    When valuetag is a AFEnumeration type is shown this error:
          TypeError: Cannot get managed object
    And if i convert to int, int(valuetag) is shown me this error:
          TypeError: '>' not supported between instances of 'NoneType' and 'int'
    Set int(valuetag) as NoneType, why?
    Regards!!!
    SOLVED!!
    I had to use the ValueAsInt32() Method for conversion.
    def value_tag(tag):
     try:
     return current_value.ValueAsInt32()
     print(ex)
  • Hi Rick,
    I managed to solve the issue after several trials.
    Please see code below:
    - the variable "summary_data" stores the result from PIPointList's Summaries method.
    - then I do:
    for summary in summary_data:
                for tag in summary:
                            for item in tag.Value:
                                     print(item.Value,item.Timestamp.LocalTime)
