PI AF enumeration set size limitations
Is there a suggested/documented limit on the number of values an enumeration set can have?
A client would like to select from a set of almost 4000 existing codes. Practically it doesn't seem feasible, as there is no scroll or filtering to allow ease of selection - instead one has to click the down arrow while it slowly scrolls through the many values.
Is there an easier way of selecting a value, or should I change approach?
Kind Regards,
Ryan
