Citect Historian Installation
Hello,
I am using CITECT HISTORIAN 2016.
I am able to install the historian but not the SQL
When start setup from HISTORIAN SQL after some time it says SQL SERVER 2012 Installation completed.
But actually there is no installation happened , no SQL server and services seen in control panel.
Shall I install the SQL Server 2012 Express and SQL Management studio externally by downloading from microsoft site.
Please reply Urgent
Thanks
  • I am using Windows Server 2012 64 bit operating system
  • Hi ,
    Can you explore the content of intsallation folder you are installing from? There should be a folder (on the ISO) called "HistorianSQL". Inside this folder is a setup.exe which you should be able to launch and install. If that doesn't work, navigate further down and find the 1033 folder, which has the SQL installer package.
    It is possible you downloaded Historian package which doesn't include SQL installer. In that case, you can either download the full Historian installer package, or download SQL Server 2012 Express from Microsoft website.
  • Hello,
    Thanks for support
    I installed SQL successfully.When I go to configure the Historian then I can select SQLEXPRESS as my data base
    But error shown "ActiveX component cant create object" and cannot proceed the configuration
    I have modified the historian installation but still it fails
    Please reply
  • Hello,
    I am not seeing any ActiveX service in services.
    Please send any document Installation Guide
    Please reply Urgent.
    Thanks
  • Hi StolzEnter,
    As Oliver said,
    Download Citect Historian 2016 No SQL setup (https://softwaresupportsp.aveva.com/#/producthub/details?id=52766) and SQL Server 2012 (https://softwaresupportsp.aveva.com/#/producthub/details?id=51206) (this is 32bit version).
    Then Copy all SQL Server 2012 files to "HistorianSQL\Extras\1033\SQL Server\" path and try to install it again.
    Make sure that before you start the installation you removed all unnecessary SQL temp files as well as applications.
